Perform this procedure to configure the remote hello interval to change how often hello packets are sent out from an interface level.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the remote hello interval:
    isis remote l1-hello-interval <1-600>
Configuring the remote hello interval on port 1/3:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/3
Switch:1(config-if)#isis remote l1-hello-interval 1
The following table defines parameters for the isis remote l1-hello-interval command.
Variable Value
<1-600>
Configures the Level 1 remote hello interval. The default value is 9 seconds.
